Now you tell me.If you choose to use lead based solders, don't eat it.
I used to strip insulation from wires with my teeth.... if those wires were tinned with lead solder, I may have ingested some....Now you tell me.
I hate it as much as you
Me, I doubt I would use lead free unless required to by law. I don't want to use a product that's even slightly harder to work with. Again, I do repair and mod work on amps, synths and pedals. Sometimes access to a solder point is very limited so solder that flows quick and easy is my main criteria.
so no reason for you or any DIYer to use lead-free solder, it turns into a pasty blob instead of being liquid like lead solder.
Not even for repairs on equipment that is unleaded?
I do the same. I have a bunch of 1L plastic bottles that all my removed lead and slag from the solder pot goes into and then taken to my local haz waste drop when full.I still use leaded, of course, but I don't throw the remaining solder in the bin. These leftovers go into a collection bucket, to be recycled with other dangerous waste, like chemical products.
Sometimes, I'm amazed at the weight if I haven't emptied that bucket in a while.
As I smoke, I don't worry about fumes too much. I've got a fan on my desk, but when doing repair in the field there usually isn't time or space for a fume extractor. In that case, I hold my breath while soldering...
