Purplenoise
- Joined
- Sep 19, 2019
- Messages
- 531
Hmmm…could I send it to you to upload?google drive, dropbox etc...
sure, over what? email?Hmmm…could I send it to you to upload?
Awesome, yeah pm me your email and I’ll send it to you.sure, over what? email?
Good day do you sell K67 type capsules? If so how or where can I buy one? Thanks.Awesome! As for shipping time, 99% of the time I do same day shipping. Usually it's packed up and in the outbox to be picked up within 20 minutes of getting an order.
the k67/k87 is currently running slightly late, seems it'll be mid january now. a lot of businesses buy stuff for the beginning of the year, so the machinists etc are a bit backed up. sorry all!Good day do you sell K67 type capsules? If so how or where can I buy one? Thanks.
Thanks. Could you please let us know when they are in stock? That’ll be great!the k67/k87 is currently running slightly late, seems it'll be mid january now. a lot of businesses buy stuff for the beginning of the year, so the machinists etc are a bit backed up. sorry all!
Thanks for the sound samples! In this application I find the Thiersch/EF800/AMI BV08 combo slightly better, despite the reduced treble.A bit of an apples-and-oranges test between:
While I set up the test to be as equitable as possible--mics positioned head-to-head into identical channels (Seventh Circle N72s), gain matched and then normalized after recording to 99.5% (in an attempt to get equal loudness)--this is clearly not at all a fair fight for the capsules. The modded MXL is much more cost-conscious in every respect. Still, after the capsule swap I think it acquits itself remarkably well.
- U47 with Thiersch Blue Line, Telefunken EF800, AMI BV08
- MXL Royer Mod with SQ Flat K47, Mullard 5840, Jensen DB/E
I hear some pretty interesting differences, but it's almost pointless to enumerate those. Too much is different between these two projects--circuit, tube, transformer, headbasket acoustics--to confidently attribute anything to the capsule design (much less the capsule quality).
What does stand out, for me, is that the modded MXL with flat K47 very much sounds like a microphone I'd use. It didn't sound like that with the stock MXL capsule.
Both mics sound good enough to allow me to hear the music before hearing the microphone (if that makes sense), which I think is the most important thing.
+1Both mics sound good enough to allow me to hear the music before hearing the microphone (if that makes sense), which I think is the most important thing.
Same here, I corrected my statement after listening several times on my best headphone setup, but I see it like you. The Royer does something in the lower mid-range which I do not like so much. The differences are not gigantic but audible.I also prefer the low end of the U47 setup... not sure I'd call the modded MXL more "boomy," but something about it is less-great. Where I really hear a difference in character is in the midrange.
+1But there's no way to really parse out which sonic distinction is a result of which variable. I figure headbasket acoustics will be a predominant factor, as will the direct box transformer compared to a really nice BV08 reproduction.
The capsule surely matters, too, but until someone does a similar test with all variables controlled, I'm afraid this won't tell us much in conclusive fashion. The signs do seem to point to Flat K47 being quite good, though.
Me too. I would also be very interested in a direct comparison of the SQ capsule in the Royer against the original MXL capsule! Of course, only if you have too much free time ;-)I'd really be interested to hear the "historically-inspired" K47 (with presence lift) when it comes out. It would be interesting to hear the difference in midrange character between the two in the same microphone.
You can't really come to that conclusion with this test simply because there are way too many variables between the two mics. You would have to test two different capsules in identical circuits under exactly same conditions. Royer mod circuit is pretty much most transparent circuit you could make with a tube.Is it just me or does the flat capsule sound very quick? It has an almost clinical sound to it.
