Roman Beilharz
- Joined
- Jun 17, 2023
- Messages
- 91
You are right, of course. It was late over here when I wrote "way more" - I didn't check the graph properly. It looked 5dB-ish...It's only about 2dB up from the base curve, a little bit less even, so it's not a ton more upper mids. Having a slope down and recession like this comes from through hole issues and also messes with the pattern response. The red curve looks upper mid-heavy in comparison but keep in mind that's a little over half as much as many neumann k47s and a third as much as most Chinese ones, at least on my setup, so I wouldn't call it "way more". I still have to decide whether to go with a mid forward tuning or a flat one like the flat k47
