alema_o
Member
Hi guys, thanks for having me in the forum, it's really great to read all the great posts, learn, and to be able to send some questions here.
I'm in a funny situation with a Behringer B1. A colleague had left his B1 mic with us about 5 years ago, because it was not working. We never did anything with it, but recently I started studying electronics and decided to bring it out to try to find a problem and fix it. After looking at it carefully, the components seemed to be all in a good condition visually, and I just remade the solder from the XLR to the board, because it was using a very thin line, and the 3rd pin had actually disconnected (not sure if it was in my hand). To my surprise, after redoing the solder, the mic worked and I was happy that I might have fixed it.
After some minutes of testing, I realised that the mic seems to "fade out" after using it for some seconds. It's as if it "charges" and works for a few seconds, and then it sort of "discharges" and the output level starts going down, until it has no sound. If we keep speaking on it, it does not recover, but if we stop speaking for about a minute, then the signal recovers and after a few seconds it starts fading out again.
Obviously, I want to find the fixes for this mic. But my problem is much stranger than that.
After analyzing the mic a lot, and then looking for info about its circuit on the internet, I realised that this mic has a very odd PCB, with big differences from the pictures and videos I found online.
I am sending some pictures attached to this post, so you guys can give me an opinion if this mic I have in my hands is fake/counterfeit, or what.
Here are the pictures of my B1:
And a pic from a B1 found on the web:
The issues I see when comparing with photos of other B1s from the web are:
1 - The PCB has no printed serial number. It does have some strange handwriting, though.
2 - There are diodes missing. The drawing of the component is on the board, but the holes are crystal clean, it's as if no diode has ever been put there. The photos of other B1s from the web actually have those diodes! These are D6 and D3.
3 - There is a Resistor 22 (R22) which has a single metal line soldered, which does not exist on the B1s I found on the web
4 - The cables coming from the diaphragm have a different path on my mic, than on the mics from the web. On mine, they are curled together through the same hole. On the other mics, they are coming separately form the diaphragm into the board.
5 - The red components near the XLR (two red squares, I don't know what they are yet) don't fit correctly on the mic structure, they are actually pushed towards the capacitors located by their side when the metal XLR mount is in its place. It looks like they should be sitting under/inside the XLR mount, in their own space, not being pushed towards the board.
I've attached some other pics on the post, showing the details I mentioned above on my B1. I didn't embed them here to keep the post a little bit shorter, but they are in the attachments if anyone wants to see.
Has anyone seen something like this? Or do you think this is a fake one, for sure?
Thanks a lot!
Thanks a lot!
