Sony C100 circuit
AUDIO FREQ
GDIY Supporter
US
Great sound but it has high self noise for my liking.
Here is a pic of the circuit if anyone is curious.
EDIT: Reverse sides of circuit.
    1.7 MB
    2.5 MB
    1.4 MB
    1.7 MB
Just curious as to what mics would be quieter than this? I used the C100 extensively and found its self-noise in actual use to be comparable to U87, c414s, KM84s, and other common studio mics. I didn’t compare it directly to our Schoeps or MKH mics, but the Sony isn’t meant to be in that league.
Respectfully, I’m not saying there isn’t room for improvement- just wondering what your expectations for this mic might be.
Hello,
Checking out the spec sheets for other mics, there are quite a few mics that are quieter. For instance the U87AI is quieter, TLM103, NT1, NT1A, and even tube mics like the C800g is quieter by a dB...
the C100 has an equivalent 19dB self noise in cardioid. For a fet mic, it seems a tad high in my opinion. In use, I noticed when boosting gain in the Apollo preamp, the mic starts to emit a white noise-ish self noise.
But who knows, maybe I have a dud?
That's rather a quirky circuit. Looks like they have an LDC capsule feeding XLR pin 2 and an SDC feeding pin 3 (via a high pass filter). Combining the two happens in the preamp.
I'd suspect most of the noise comes from R152 in the LDC's impedance converter, that's 4.7k's worth of thermal noise right in the signal path. Seems sloppy to me - I wonder how it ended up like that?
You have verified the noise isn't the preamp by strapping an input resistance, such as a standard mic pad? Tried a different preamp channel? Different preamp?
Any ideas to modify it for lower noise? How would you have designed the impedance converter, lower resistance at R152?
It comes with a pad. And yes i've engaged the pad on it as well as other patterns just to experiment. I use a plethora of different mics, and noticed the C100 is noisier. The spec sheets says 19db of self noise, and yes I have tried it on other pre-amps aside from the preamp in the Apollo Twin X and Apollo Twin X6. I have tried it on Focusrite 18i20 and Presonus Eureka with Jensen Transformer.
Not the pad on the mic. Using a pad as a way to load the preamp with no mic attached, evaluate its noise.
I personally can’t say I ever have problems with mic noise in the real world, nor with preamps of which I use a lot of antique technically noisy tube types, unless the source levels are so small as to suggest the wrong mic or preamp is being used for the job. Usually the rare noise problem is asking a ribbon and a high gain tube pre to do more than is reasonable for the situation. Air motion alone is usually the overriding noise source, swamping all else, outside of any hum fault.
It’s very easy to look for noise problems in a vacuum and find them, then use the same equipment on a recording job and hear none. I’ve been down that road numerous times.
Haven’t used this mic, but like poster #2, am skeptical that Sony would release a mic like this with a questionable noise floor. There’s plenty of recommendations for it from classical recordists, ambient usage as the S in MS, etc. It wouldn’t fly if considered noisy by those users. Maybe there are faulty samples out there. I’d certainly dig into that further.
