Spiritworks
I have an early serial # 0143 that is exhibiting what appears to have been a common problem, based upon my current internet searching. This microphone has a small toggle switch which can change between V mode and I mode = vocal or instrument. We pulled it out of the locker to use on the bottom rotor of a Leslie 122 for a session the other day and, in I mode, there was little to no signal passing and a lot of crackling, sputtering noise. No problem in V mode. Toggling swiftly back and forth to perhaps clear some intermittent connection on the toggle switch had little to no effect so we changed out the mic to get through the session. Later on, I injected some DeOxit into the toggle switch and worked it back and forth. This seemed to help a little bit, but results were not conclusive. I have not yet attempted to actually disassemble the mic for further repairs.
Any suggestions for continued repair attempts, short of sending the mic out to someone?
