[quote author="Emperor-TK"]EUREKA! This thread helped me solve my GSSL problem! My ear told me there was something wrong with my build. There was distortion, particularly on the lower frequencies. Also, the compressor just wasn't responding right. It just sounded bad, and I couldn't quite put my finger on it. It was a choked and strained sound.
After buying Audiotester, I went to work. I benchedmarked the GSSL vs. my RNC and Behringer compressors using the FFT and looking at the relative harmonic to fundamental ratios. The GSSL was definitely putting out more distortion than the others. Also, the RNC in "normal" mode has a similar amount of low end distortion. And I already knew that I hated that compressor for any low end material (except in "super nice" mode). So my ears weren't lying. Still though, my GSSL didn't sound as good as the RNC, which has too much low end distortion, but doesn't sound choked.
The solution was in the VCA inputs, as discussed in this thread. I also used Audiotester to measure the compressors response as described by SSLtech. 2:1 gave me 3.5:1, 4:1 gave me infinity, and 10:1 gave me an inverse response (greater than infinity). Originally, I had used the DBX c1252h2 VCA's. I changed those out to THAT2180LA's (thanks Zach) and the distortion went away. I played around with the resistor feeding the negative input of the TL072 just before the CV inputs (as suggested by Steffen). I needed a 122K resistor here and I am now getting normal ratios. No more choked response!
Can anyone comment on what the pro's and cons might be of changing the input resistor to the op-amp vs. the input resistors to the VCA CV's? The one thing I can see is that the make-up gain won't be effected with the op-amp input resistor (which is good I think). On the down side, I now need to tweak the resistor feeding the meter so that it shows the correct amount of gain reduction, but that should be easy.
Anyway, I am VERY excited now. Cheers to Jakob, Steffen, SSLtech, Gus, and everyone that has shared their general expertise and experience on the GSSL.
:guinness: :sam: :guinness: :sam: :green: :thumb:
-Chris[/quote]
Sorry for the stupid question, but...
Ok, so you say you had to re calibrate the GR on the meter.
Say if your threshold is set to show 8db of GR, as Keith suggests...
Then at 2:1, you increase the input by 10db, ideally for a 5db increase at output...
the meter should show 13db of GR ?? Is this the way to calibrate it ??
Trying to understand.
