clintrubber said:
Sound like we've found yet another board/gizmo/feature that could be added to those cases:
the M-S matrix (from L-R to M-S & back again) Anybody properly done that yet for the GSSL ?
Peter, I think I discussed this a while ago with someone, and the thing is that -in both turbo and GSSL modes- it's probably a significantly less useful idea, if you give it some thought.
For one thing, the GSSL will simply sum both channels to one... M/S is basically L+R on one channel, and L-R on the other channel. The GSSL sidechain mode sums both together and compresses that. Therefore, Since L+R+L+R = 2L, only signals on the LEFT channel will be compressed, the right channel signals will pass through completely uncompressed.
So that rules out any real usefulness for M/S with the GSSL... but while the Turbo version will work rather more 'typically', I still contend that you shouldn't M/S compress with a stereo compressor.
What you CAN do with M/S is two use two COMPLETELY DIFFERENT types of compressor: one for the 'mono' part of it (*which is basically what the GSSL does anyway*) and a second one for the 'width'. -What this will do (and you
need to be wary of this) is to artificially widen any narrow parts, and 'narrow' any LOUD parts to either side.
Using a DIY SSL clone in 'Turbo' mode through an M/S matrix will squash the signal when the mono-sum gets loud, but ALSO when anything loud gets panned AWAY from center... Not necessarily greatly different from the GSSL mode in practice for most of the time, since anything panned away from the HARD edge will ALWAYS sum louder in L+R than it will in L-R, and thus the L+R channel will dominate the compression. Only (usually random, occasional) opposing-polarity stereo acoustic clues will sum higher in L-R than L+R, and these make a phase meter go completely batshit bezerk, and you'd usually notice even without a phase meter that something is 'wacked' if these were louder than the main center signal...
It might be a useful effect for certain applications, but myself, I find that M/S works brilliantly well for EQ and similar processing... though the whole POINT of M/S is to process the two channels DIFFERENTLY... otherwise, there's NO difference compared to just running it through a non-M/S piece of gear.
-Been there, studied that, found that it didn't work. -Remember that on a Fairchild 670 there were independant threshold controls for EACH channel... VERY important that you don't overlook that.
Keith
