tonycamp
dandeurloo said:There was another member doing true bypass boards with a built in psu. That is what I put in mine.
This is the one Dan is talking about.
http://www.groupdiy.com/index.php?topic=44049.0
germoju said:Hi,
here is my Dual 1176 in a a Purusha case (very small !)
Take a look : http://flic.kr/s/aHsjGfrsE3
dacapitan said:When using the external PSU I noticed http://mnats.net/psu.html is using the G1176 board and the Jumpers do not match the parts on M.NATS 1176 rev D 2.2 PCB
I noticed germoju has CR7 going to <+30V (R87) and CR10 going to -10V (CR6)
Is this correct?
I have not been able to find any explicit answer to this.... but I have noticed the question come up, unanswered.
hymentoptera said:germoju said:Hi,
not sure what's causing the humm, maybe something external, like computer monitor, or...
I just wanted to say that your dualie looks good. I like how the boards are stacked, I was wondering myself if that was possible in a 2RU enclosure. Hope you get the hum issue sorted out soon!
eparg said:dacapitan said:When using the external PSU I noticed http://mnats.net/psu.html is using the G1176 board and the Jumpers do not match the parts on M.NATS 1176 rev D 2.2 PCB
Is this correct?
I believe you can wire directly to the test points (+30,-10,gnd) without having to jump anything. I could be wrong. Best to check the schematic to be sure. Also verify (beep) with a multimeter.
Hope that helps.
dandeurloo said:Did you remove the paint behind the switches and pots so they make solid contact to ground? You don't want them to float.
Many people have built stereo 1176's into my cases with no noise. The project is great in a 2u. My guess is something ground related.
germoju said:eparg said:dacapitan said:When using the external PSU I noticed http://mnats.net/psu.html is using the G1176 board and the Jumpers do not match the parts on M.NATS 1176 rev D 2.2 PCB
Is this correct?
Hope that helps.
Yes yes ....
you can plug directly to +30 and -10 without jumper cause you come from the PSU Board witch gives you the +30V / - 10V.... And that a better solution to avoid jumper...
germoju said:Yes I did remove paint between switches and pots...
