Studer 900 channel strip in a rack - getting the right output level
saint gillis
Brussels - Belgium
I m putting 2 Studer 900 channel strips in a rack, made the PSU
  Here's the channel schematic :
ftp://ftp.studer.ch/public/products/Mixing_Analog/900/Manuals/900_Op_Serv.pdf
Pages 199->202
So I m using the pre-fader send output (page 201 at the top right corner)
  It is a 0db unbalanced output so the signal level is ~ half the input level (with a line input for instance)
So I tried this, wich is in the fader block :
It works well; but in a symetric output isn't the cold pin (b) supposed to get the same level as the hot pin (a)?
Here the cold pin (b) signal is about 1/2 weaker than the hot pin (a) signal, is it normal?
