LevinGuitar
- Joined
- Jun 13, 2019
- Messages
- 482
I once found (by a chance) a broken wire inside the plastic cover of the transformer leads in a SP TB1, so just to exclude that case, measure resistance between your transformer leads:
Between Red and Yellow (should have around 1.35K) and between Blue and Green (should have around 40R).
Also you can measure resistance between pins 5 & 6 of your microphone 7pin connector: if you still have that 40R, the audio output path works.
After this, look for capsule connections and capsule membrane shape itself. Also check out all component and tube socket soldering
