I live on an island where the power grid has been struggling with overdevelopment and under-investment… as a result the grid has been really struggling. It gets really hot in summer and the distribution network has really struggled to keep up, high voltage cables running below roads burn up and other fun stuff.
As a result, I’ve been keeping an eye on the voltage I’m seeing at my outlets and during really bad times I’ve seen some crazy swings (118v to 308v!!) when our nominal spec is 230v +\-10%. This was on a particularly bad day where I think there was some kind of a major fault somewhere nearby, but circuit breakers didn’t trip and I only noticed as a fan I was running went from super slow to extremely fast. Needless to say I disconnected the house from the mains and sat it out.
I rarely see the voltage drop below 243v or so… I guess they’re running the grid at a higher voltage to take some pressure off the distribution system or something like that.. voltages regularly hit 250v and the “over-under” cutoff box I’ve had installed just after my meter cuts off power every few days when it hits 255v..
we’ve never really paid attention to voltage specs on any equipment imported, so stuff around the house can have anything from 220v 230v or 240v written on the back..
Considering most specs are +\-10% then:
220v = 198v - 242v
230v = 207v - 253v
240v = 216v - 262v
I’m running some equipment that could be very expensive to repair, so I feel it is wise to try to deal with this voltage, and I guess try to get it stabilised to the nominal 230v (though with the supply seemingly coming in around 240+v I wonder whether it is wise to do this)
I’m running a newer console that is rated 100-240v +\-10% but if the psu’s get cooked I’m looking at many thousands in replacements, so it concerns me.
I’ve also got a fair amount of rack mounted gear
I run a few vintage amps from the US that are rated for 117v, I use cheapo step down transformers for this(though would like a more sophisticated solution in the future)
Otherwise, I often have up to three split air-conditioners running some days, so there’s quite a load from these to consider
I’ve unfortunately got the whole studio running on a single electricity phase, as though three-phase supply is available, rewiring the whole facility would be a massive job.
I’m trying to figure out how best to proceed here.
Do I get a few smaller and more affordable voltage stabilisers? Perhaps a 5-10kva one for the console that is spec’d as 1.54kW with an “over voltage range” (peak inrush current) listed at 14A,
And maybe a couple of 1kva ones to run my outboard rack, and another one or two to float around and be connected before the step down transformer for the American amps, etc..
I’m not sure “voltage stabilisers” is the correct term for what I’m looking at. We’re talking the boxes with the large toroidal inside..
The smaller ones(1kva) are available locally for about €50 each, whereas a big 8kva goes for about €250.
Is this a sensible solution for my situation? Or do I need to go for something a lot more expensive but unfortunately more suitable for the application?
Do I go for a big one and have the whole facility run off it? Our single phase supply is fused for 40A
Should I be concerned from an audio perspective with any of this? Might I introduce noise to the system?
I remember working in a studio years ago in London that had a pretty massive transformer doing this(as it was explained to me) locked away in a back room and it make a very loud noise (a buzz) all the time. Is this to be expected? Should I look to install this in a box outside? Would 40°C(104°f) summer temperatures be a concern?
Any advice would be very appreciated. I’ve spoken to a number of domestic electricians locally and they don’t really have much insight to offer.
Sorry for the essay… thanks a bunch for taking the time to read all this
Bob
220v = 198v - 242v
230v = 207v - 253v
240v = 216v - 262v
Bob
