Michael Tibes
baadc0de said:I left the "unused" AOTs empty, should I replace them with wire links?
no
baadc0de said:The problems I'm having right now are pretty basic I think.. the left channel's VU goes "down" and pegsa, instead of "up" to center at 0. The right one pretty much centers at zero (both are with hold set at middle, link disabled). If I turn the hold knob I can get the left one to deflect a little, while the right one seems to have a pretty much healthy swing imitating my hold setting. Both VUs and hold pots are wired the same (I checked) as are the wires connecting the small attack/release boards to the main boards.
The VU on mine is zeroed if hold is off (full clockwise) and then rises when hold is turned counterclockwise. I believe that's how it's supposed to be?
baadc0de said:After some time (say one minute) the right one's VU starts oscillating a bit, i.e. the needle goes up and down like a metronome. I think it's about 60bpm.
I put some sound through the left channel, but in iron mode I'm not getting anything and in clean mode I'm getting sound that isn't dependent on the input sound or volume (input can be muted / non present / disconnected but it will still do this). It's kind of like a complex square wave with some additional stuff soperimposed on it. It's definitely "synthesized" sounding. I may record a clip of it. It's very quiet though, about -50dB on my interface.
Recheck your wiring, probably somethings mixed up. If you can't figure it out you might brake thinks down into logical parts - check your input stage - check your output stage. Remove the compressor pcb from the audio circuit, connect only the out of the input stage with the in of the output and make sure it works as advertised etc...
Hope this helps a bit,
Michael
