I'm still deciding on transformers but will most likely be going with the Carnhill VTB 2281 for in and outputs. That way I'll have +6dB in and out but most importantly input as the comp needs a decent level to get it working. On the flip side you play with AOT 3 and 4 to change the threshold of the comp mode and AOT 5 and 6 for limit mode.
I'm using 100% original semiconductors as per 1969 schematic.
I'm only doing preliminary testing at the moment with no transformers, OP amps configured for +6 in/out and output going to headphones as I would not want to destroy my Apogge converters if something went wrong. The compressor sounds great, no unbelievably good.
Now my thoughts on the resistor that keeps burning out is that because you are driving a low impedance output of the transformer primary more current is need to for a given dB level. I have no problem with resistor temp at the moment a I'm driving a high impedance load. Does the resistor burn out only when you have the iron switched in. I have been smashing the unit with dance music (big bass) for hours now with no issues.
I'm also using a 10K lin hold pot and R115 jumped.
More details to come as I finish off this project.
Regards,
Brezo.
