baadc0de said:
One interesting problem for the crowd here, maybe someone has any ideas..
Sometimes, when excessive low frequency information is in the input (such as from a preamp when recording a kick drum or direct bass guitar) and the gain reduction is set to a slow enough attack and quite a bit of makeup, the TG1 starts smoking R77. Could the output transistor pair be somehow to blame? I don't know enough about transistors, but say if one of them faults into being a straight line for a time?
It all works out if I power it off for some time. The output transistors are not heatsinked, maybe I should do that?
Ha! welcome! You're not alone. I've been mentioning this problem for quite a while but unfortunately it looks like a mystery
http://www.groupdiy.com/index.php?topic=37400.msg512287#msg512287
http://www.groupdiy.com/index.php?topic=48297.msg617261#msg617261
I'm pretty sure it's not a heat problem as I'm using heatsinks on the transistors. What transistors do you use?
What wattage is the 56ohms resistor? Do you have good heatsink on the PSU regulators?
In my case a 2watt resistor with a BIG heatsink on the regulators gives me a maximum of around 40C which I suppose it's OK.
Still though, I don't know what causes it. :
Good luck and let me know. It's been my nightmare for more than two years now ;D
It'll be good if other people can report too.
