bruno2000 said:mrclunk said:There isn't any layouts avaliable.
Igor was smart making black PCBs, you can't scan them to make copiesI tried before stuffing mine.
Don't be so sure..........
Bruno2000
Haha, you tease!
Bruno2000
Spencerleehorton said:Isn't it time for someone to make some more then?
I only have the facility to make single sided boards, is there any printouts or anything layout wise?
Regards
Spence.
That sounds like the 20uf's that I found. They are pretty big. Yeah, it is interesting that it was designed this way.desol said:Nice. Thanks Duantro. I did find some 20uf caps on ebay...but they seem to be mostly only available in larger axial packages.
I like matching parts to the board print, lead spacings, etc...if I can. I've wondered at time why Igor chose radials in this spot instead of axial's, which most of the 20uf's seem to be. Glad you're happy with yours!
Rob Flinn said:Why don't you guys use 22uF caps. They are well within tolerance and easy to get. Electrolytic caps have poor tolerance.
mrclunk said:i used these
http://uk.farnell.com/panasonic-electronic-components/ecqe2475jf/cap-film-pet-4-7uf-250v-rad/dp/1744798
mrclunk said:Not 100% but isn't that just an output coupling cap? Don't have the schematic but larger should be fine.
