bruno2000 said:
It helps if VT13 and VT14 are fairly close hfe match. Switch the comp in / thd switch to thd, eliminating the audio feed to the side chain, then measure the AC Voltage at T_F and T_G. Should be 0. Then measure the DC Voltage at T_E. Should be the same for both channels. I'll check the actual Voltages on mine this weekend.
Bruno200
Hi Bruno,
Finally got time to take some time.
So here the Voltage I get.
The problem is on the Channel A. Don't have unity gain in comp Modo.
Channel A Channel B
Ref | Comp | THD | Comp | THD
T_G | 0,90 | 1,62 | 1,55 | 1,55
T_F | 2,37 | 1,74 | 1,67 | 1,73
T_E | 0,62 | 0,62 | 0,62 | 0,62
Thanks !
