salomonander said:alright so i finished wiring this beast up. what a massive pain in the butt!
im too dumb to finish though... maybe one of you can be kind enough to help me out.
so i've got my +-28v lines and sifam meters that ask for 24v. i lack the electronic skills to figure out what to do. please help
can i connect it like the bypass led (insertig it between +-28v with a 10k resistor)? the sifams already have a high watt 1k resistor soldered to the led. thanks a lot
r2d2 said:am i wrong or there are headaches for all tastes ?
wrong parts details , partial / incomplete info , etc…
Rob Flinn said:Not really. I have built 2 working examples of this project & have a 3rd one on the way. The information is there, it's just not handed to you on a plate like quite a few of Igors projects, & you need to think through what you do.
desol said:Maybe you could elaborate Rob on things you think people need to think through on this project. I still have my complete(unbuilt) set here. Just thinking off hand, I couldn't even figure out the power wiring scheme. Each board has 2 power connectors I think, as well as the power supply board? Pwr1&2?
and this is so cool ( many i-o options )Rob Flinn said:…. This is mainly because there are so many options. e.g op amp in/trafo out, op amp in/out, trafo in opamp out. trafo i/o & switchable op amp i/o. …...
r2d2 said:and this is so cool ( many i-o options )
Well in my experiences it doesn't make massive differences to the sound & it makes it difficult for peopl like yourself to figure out how to hook it up.
and something like a wiring / setting guide as made for the PPR vari mu comp
will be a very great help,
(for not very expert tech)
but only who have finished a working unit can give the info about ,
Yes, I can understand that, but I think Igor wanted people to learn from the process of building, & having aa paint by numbers approach doesn't get people thinking about things.
cheers
ps
are the pcb for the 51x version
still available somewhere ?
Igor disappeared about 4 years ago so unless someone else brings something out like this you will have to find them used.
Thanks Rob for info !!!Michael Tibes said:The wiring was actually pretty well documented by Igor, though it might be confusing at first because of all the possible options. The calibration not so much though, I believe it really requires understanding the provided documents and all the information that came to light during the initial consolidation phase. Or was there ever a calibration document that I missed?
Michael
… probably "yes" ,Rob Flinn said:…...I'm pretty sure that all the info needed was on this thread or in the docs. ….
weiss said:The output volume with my tg1 on one channel is slightly louder compared to the other. What would be the easiest way to fix that so i can match the output switches?
Rob Flinn said:Did you match the diodes between channels ?
Ilya said:If the level mismatch is not large (1-2 dB), you can trim it out with AOT resistor in the GR section (don't have the schematic at hand, so can't tell you which AOT exactly). It sets the idle current of the zeners, so it should work for small level adjustment.
weiss said:Thanks Ilya! Do you mean AOT1,2 for Unity Gain ? It's max. 2dB.
Ilya said:Yes, those AOTs. They are good for small adjustments, and if your zeners are not that well matched (between the corresponding pairs of stereo channels) this might not do the trick. But it's a good starting point. I'd check compression curves after gain matching.
How close are your zeners matched? What did you use for matching?
