ill just keep talking to myself here.... maybe someone replies after all
now first of all i get the jumpy meter with no in or output connected. its just in the circuit. when i try to get the needle to 0 on full hold it starts jumping up from 0 and back down. i can varie the lenght of the "jump" by the release switch. so its something triggering the sidechain falsely. also my 10v voltage on the hold switch gets jumpy on max hold.
now another issue im having is that i cant adjust the voltage between VT5 and VT6... which might cause the entire problem.
i am capable of adjusting AOT7 therefore matching the basesupply on VT5 & VT6. this gets the collector voltage to almost the same - but AOT 10 shows no effect at all on T_B and T_C.
matching the base volatges via AOT7 actually cures the needle jumping! but why does AOT 10 not allow me to fully match this (resistance from AOT10 to 20v rail moves correctly)?
any ideas? could my initial zener matching be too bad and responsible for all this?
thanks a lot!
another thing im wondering and need to clarify is the set up procedure. step 5 says:
set unity gain. Set HOLD and OUTPUT to 0 and switch the compressor side chain out by selecting THD. If you have the correct 2.5mA FS meter it should read zero, if not adjust the 100K trim pot until it does. Apply 0dBu (0.775V) 1KHz sine wave to input and measure the output on a oscilloscope or DMM. You need to adjust AOT1/AOT2 so that you get 0.775V at the output.
now, with a 5k linear switch and R115 being 5k for my hold - where would my "Hold 0" be as to referred in the set up? to the far left or in the middle position?
