dogears said:Hit "S" to generate the command line prompt.
In the box make sure it's generating a spice command not a comment. Type .include ((filename.txt)) and place that anywhere on the "paper". It'll run when you hit run.
To Ground.....good morning, can someone tell me where the cold signal of the transformer is connected?
I used 1:1 for both i/p & o/p. Works well.Hi everyone, I bought one of the Igor clone builds years ago with no input transformers and have since bought two Sowter 1715 transformers for the inputs, which were a recommendation from brian sowter for the tg12413. I wanted to confirm with you guys that the inputs should definitely be in 1:1 configuration for this build, resulting in no level drop, right? In this case 600:600
I used 10k:10k which is pretty normal for this type of circuit.thank you so much Rob! I see from the thread you built a few of these, did you find any particular input impedance worked better or worse for you? I recognize it was a while ago now, do you happen to recall?
To be more specific that is 10k:10k for input BUT 600:600 on output.ah okay, I guess 10k will match better with modern gear? I guess the original unit was quite low - hopefully I didn't make a mistake going that way haha
Carnhill do a 10k:10k transformer www.audiomaintenance.com/acatalog/CA-18-VTB9071_extended_info.htmlI'v got 600:600 carnhills on output - I guess 600:600 on input as well might work poorly?
