qwerty8787
Active member
- Joined
- Oct 16, 2011
- Messages
- 34
Hi all,
I'm building a preamp based on the THAT1512 IC, pretty much following the datasheet suggestions (http://www.thatcorp.com/datashts/THAT_1510-1512_Datasheet.pdf)
I'm trying to make a direct injection input for it, selectable via DPDT switch (commutes the +/- ic inputs from the +/- mic signals to the buffered DI input).
The DI input is a non-inverting opamp buffer with input voltage divider for attenuation. The output from it goes to a 10uF Non-polarized electrolytic cap, then pulled down by a 10K resistor.
The output of the 1512 is pulled down by a 20K resistor in another section (not present on the images below).
These are the schematic:
The problem is that in DI mode, at max gain (about 65dB) I have something like 15Vdc offset on pin 6 of THAT1512 IC in the worst case.
I managed to get about 3Vdc playing with pulldown resistor on inputs (removing R213) but it's still too much.
On the mic mode (SW102 switched) offset is about 200mV @ max gain, so it's good.
I can't understand what could be wrong, does anybody have any idea?
Thanks in advance!
Thanks in advance!
