Harpo
DS201 schematic attached...gyraf said:That's for a 202 - what is the difference from 201?
Jakob E.
Jakob E.
That one is probably AOT; it must be so that the FET is off without signal.Spencerleehorton said:from the base of the first 2N3704 down to gnd?
According to specs, the relase time is adjustable from 30ms to 5s. 2Megohms for 5s imply 12kohm for 30ms. There is already about 2 kohm (10k//2.7k) at the foot of the pot. I would vouch for 10k.and after the third 3704 connecting to the release pot?
http://www.analogrules.com/manuals/outboard1.htmlSpencerleehorton said:Anyone have any thoughts on this and a schematic for the kepex?
Spencerleehorton said:Ah ok, so the second resistor i'll try a 10k, thanks, don't understand the AOT for the first one sorry? not good with acronyms!!!!
My simulation shows very little difference between 50k and open circuit. I would suggest a 500k trimmer with a 50k padding.Spencerleehorton said:ah ok, i understand now, so would 50k trim be too much in here or does that sound about right? or should i go 500k?
I have already posted about that, perhaps more than once..Spencerleehorton said:All great info thanks, I will put this together first and put trimmers in those places so it can be tweaked!
Once done and working I think the next step is putting something in the circuit for sidechain eq’ing for better gate response.
Any thoughts on how to implement the sidechain with eq?
JohnRoberts said:#1 Easy and most powerful is an insert jack that allows you to patch in a powerful external EQ for problem tracks.
Easy from a design perspective...Rob Flinn said:I would debate that this is easy because you either need to tie up an eq or need to build some eq's to insert. If you happen to have a bunch of patchable eq's that you don't use then maybe it is easy.
My personal take is a High-pass and a Low-pass, à la DS201. I've used EQ's, both parametric and graphic, in insert; I've not found it was any better.Spencerleehorton said:Any thoughts on how to implement the sidechain with eq?
Spencerleehorton said:Ok so high pass a slow pass sounds good, could we have some docs attached so I can see how and where to implement please.
That one.Spencerleehorton said:Still not quite sure which 3.3k resistor you mean to be bigger?
Is it the one attached to the collector of the 4th transistor
