The microphone capsule photo and information thread
"rayking" is just a backronym from RK (Recordinghacks K) and doesn't exist. "Rayking" capsules are just from AYM, I think. This specific capsule is made of AYM parts but probably not AYM assembly. Lots of smaller factories buy parts from AYM or through AYM but assemble themselves. Like I said, I'm pretty sure (but not positive, as I don't handle domestic chinese business) that this is one of our domestic china models. It can be told apart from the AYM-assembled part by the wire colors, materials, leads, and diaphragm thickness mostly. It could also just be a fully AYM-assembled part with different specs.
Mackie Element EM-91C. On the package they say it is "Large-Diaphragm Condenser Microphone... built like a tank". I Think this is just another version of the BM-700 with small diaphragm cardioid electret capsule with fet. Saddle is made of flexible plastic. Bought from Cl4s 0hlson with quite good discount with mostly metallic shockmount and XLR cable (approximately same price as typical BM-700 from The Bay).
I have not seen this kind of capsule wiring with only two cables (black (-) connected to S and G and red (+) to D) before. Is it a conventional way to do it?
View attachment 138224View attachment 138225
Great joke! May be some translation issues 😂
By the way - what purpose this Holed Halo or Old Phone Dial shaped capsule holder serves?
I've seen this already on (around?) some other capsules (and was too afraid to ask).
Is it meant to condition or deflect sound waves somehow or just Look Vintage & Cool?
It's because that version of the capsule has a built-in FET. It's under that PCB disc with all the holes in it.
The S, G and D marking are misleading on these, as there is no external connection to the Gate.
It's this capsule (or equivilent thereof):
https://www.jlielectronics.com/content/JLI-140A-HD.pdf
It's my understanding that it renders the capsule less directional at low frequencies giving it a behavior in that respect that's more like a dual-diaphragm LDC (of course, I could be wrong ;)).
I too have been wondering. Audio-Technica uses that kind of holed ring around some LDCs, and MXL uses an un-holed ring around their smallish-diameter condensers that look like LDCs. There are also capsules that appear to have some or all of the holes covered or filled with flow-resistive material, like silk or foam.
I'd think that the un-holed ring makes it act sort of like a boundary mic, increasing sensitivity for high frequencies (with wavelengths small enough to reflect off, not just flow around). And making the diameter larger (and path length around the capsule edge longer) presumably affects the directivity in ways I don't understand.
Do the holes soften the transition between the high and somewhat lower-frequency behavior? Or do they serve some other purpose?
Electro-Voice PL84 handheld end-addressed 16 mm OD electret. I like the form factor (and the rubber surround of the casule mount seems to provide decent isolation). Is there some premium capsule that would fit and predictably work well in this kind of mounting?
    900.3 KB
    887 KB
Man, the number of microphones that capsule shows up in is astounding!
For upgrade, I'd reach for the Primo EM200; at 14.6mm, it only needs a bit of shimming to fit. A fabulous electret cardioid.
https://micbooster.com/microphone-c...m200-cardioid-electret.html#/99-type-no_wires
It has it's own FET built in, so you'll have to mod the EV circuit to suit.
This one https://www.jlielectronics.com/microphone-capsules/tsb-25axz3-gp would be a considerable improvement, and likely work just fine with no mods to the circuit, but at 25mm may be a challenge to fit/mount.
Hi All, here some information about MBHO SDC capsules as seen in my profile pic:
The explosion picture is mbhoconstr.jpg: capsule body, front metal mesh, resonator element, membrane glued to a holding metal ring, spacer, complete backplate, plastic cap, metal rings for fixation.
For the KA20 and TC600 capsules two different backplates exist, see bpl_ka20.jpg and bpl_tc600.jpg.
The backplates are mounted in plastic baskets. They have 6 ventholes to the rear, see 6ventholes.jpg.
These 6 ventholes are covered with cushion mesh, see mesh.jpg. KA20 has 6 layers of mesh, TC600 has 9 layers.
A rubber cone is attached and puts a defined force to the cushion mesh layers when the plastic cap is attached.
The membranes are made of 6 um mylar with metal vapourisation. Newer capsules have gold vapourisation..
BTW: For my oppinion one of the best SDC capsules on the market...
    1.9 MB
    1.2 MB
    1.4 MB
    1.7 MB
    1.8 MB
