gemini86
Yes
bruce0 said:MeToo2 said:Are you also using a "make before break" switch for SW2?
Maybe you can probe with a 10Meg scope for any DC offsets before and after the pop?
Yes... MBB but I modified BBM to make them that way, so maybe I screwed up.
Re: Probe prior... that is what I was planning, thanks
mrdarwin said:Hi!
I just finished my G9 preamp and I need help please!
The instrument input works perfect, on two channels.
But I've got some trouble with line/mic input...
I loose very much signal, like a low cut at 400Hz... On channel 2, 48V works and sometimes doesn't work... and big noise/hum on each channel.
I tried to bypass the relay, feed signal directly to OEP transformer, no change. It's strange because the input instrument is just after OEP and it works!..
I use OEP transformers input and output with screening cans. I'm sure at 99.9% I've put A3E on input and A2E on output.
I use Axicom Swiss relay C93402.
So if the someone has an idea...
Please tell me if the answers is on a page of the 70 of this thread, thanx.
And please sorry for my "french" english.
mrdarwin said:Thanx for the answers Braeden.
So, my input instrument on front panel is 1/4 switch jack but well wired (I think)
And my mic/line input on rear panel is a XLR connector.
I will try your exam and tell you. ( I couldn't work to G9 before wednesday...)
gemini86 said:check out your wiring and correct parts in the 48V power supply section. Sounds like your voltage regulation is not working there. Double, triple check all your wiring, this is the biggest cause of problems. Also, did you do the DI wiring modification?
gemini86 said:Well, the relays are identical.
some relays may have a built in diode across the coil to suppress voltage spikes when the coil is deenergized. The omron, as well as yours do not. That is good. So it won't matter if you swap the +- pins, but there's no way to actually do that, since it has to fit in the PCB.
Check:
1) wiring from the input transformer's secondary windings is correct. It should go from the transformer secondary to the instrument jack's normally closed pin (on the tip contact), then from the tip contact to C2. Look at the schematic for a clear view of what I mean.
2) Check out the 48V supply. 62V is much too high, and that's typically the voltage seen on the input side of the regulation, just after the voltage tripler.
after that's all good, then you can worry about the relay.
