braeden
That's good to hear, also... I hate Farnell :-X
Oh well, if thats the case i will have to forget about it. Since i am using normal transformers, not toroidal ´cause they are very expensive here in Argentina(and i havent seen a 220:240 + 15+15).gyraf said:..if you have same-level hum, regardless of gain setting, it's likely to be power transformer hum introduced into output transformer. Try moving/rotating power transformer(s) and/or move output transformer further away from power transformer..
Jakob E.
Graph said:Oh well, if thats the case i will have to forget about it. Since i am using normal transformers, not toroidal ´cause they are very expensive here in Argentina(and i havent seen a 220:240 + 15+15).gyraf said:..if you have same-level hum, regardless of gain setting, it's likely to be power transformer hum introduced into output transformer. Try moving/rotating power transformer(s) and/or move output transformer further away from power transformer..
Jakob E.
Channel 2 is unusable, moved transformers and tubes to channel 2, and there were more hum than signal.
Weimann Stage and Sudio said:Hey Guys,
First im new in this forum so i like to explain myself first:
My name is Michael 21 from germany and im working as a event engeneer and my english is ot the bestsorry for that.
im a diy er fo about 3 years but now its time to get some "serious" studio gear
So:
Im interestet of building the G9 my Question: is there an up to date BoM? would be Great ...
Thanks and have a nice sunday, Michael
I cant, i have to send it to make them, and minimum order quantity = 10 of each one, cost like 80usd each one(total 20 transformers = 1600usdgemini86 said:Can you find a 220:12v and a 220:15v toroid?
then wire them back to back, just like the schematic shows.
Yeah, but 4 times its international price.gyraf said:RS Components and Farnell are represented in Argentina afaik?
Jakob E.
