Hello everyone
I'm a few steps from completing my first G9 build. As expected I ran into the usual problems: hum and oscillation, but besides from that, things worked seemingly ok (I did only measure 211V at the 245V HT test spot though, but that is hardly related to hum or oscillation issues).
Here are the (somewhat scary) test numbers before applying any hum/osc. fixes (i.e. plain unshielded molex connections):
CH1:
Hum
Input @ step 6, Out @ Max
Btwn. Gnd and Hot/Cold = 350mV @ 50Hz
Btwn Hot and Cold = 9mV @ 50Hz
Oscillation (step 9-11)
9: 25V @ 4.6 kHz
10: 15.8V @ 7.1 kHz
11: 7.4V @ 6.0 kHz
CH2:
Hum
Btwn. Gnd and Hot/Cold = 190mV @ 50Hz
Btwn. Hot and Cold = 11mV @ 50Hz
Oscillation (step 8-11)
8: 20.5V @ 3.8 kHz
9: 7.4V @ 2.2 kHz
10: 3.9V @ 1.0 kHz
11: 3.6V @ 0.5 kHz
I have the trafos mounted side by side (not on top of each other) on the side of the chassis (to get better heat dissipation) - as far away as possible, and plan to shield them better later on.
I cut the pcb lanes as instructed in the gif posted earlier (http://www.gyraf.dk/gy_pd/g9/G9-EDIT.GIF) and rewired with shielded cables and did a test - silent as h***, no oscillation etc. almost too good to be true, so I tested with a mic (still only hooked up to the scope). There was signal, though weak.
Then the smell came. The sour smell of fried semiconductor :-/ It was D15 in the rectifier block near the hot as hell regulator (which do in fact have a cooling profile attached, but I fear its too small). The main trafo also started getting warm and humming directly from the box. Time to turn it off and head in here...
What killed D15?
Could it be the testing period it self - I had the oscillating steps going at full output for some time (maybe 15 mins or so)?
and while I'm here, a few other questions:
- I'm supplying 230V - why is the additional step trafo needed at all? Why not take the fused main supply directly?
- I'm using two 100 uF / 400V filter caps - but I've seen other recommendations, any point in going up in capacity here?
- Is the side by side mounted ring trafos a bad idea (increased inference issues), if so why?
Regards
Michael - (long time lurker in here)
