janczmok
Mike D said:
Is anybody able to provide me a replacement Amphenol C091 with the small ALu Backplate ? It got lost in my workbench and i'd like to finish my PSU
and fire up the big box ...
Mike D said:
Dualflip said:Does anyone have any experience with the Stereo link jumper, meaning which compressors do work with it and which do not?, 500 series compressors are something new to me, i havent actually seen any 500 compressor with a stereo link switch on/off in it, so this must be a hardwire, which is ok by me, but dont know if it will work with any or most compressors....
Yes! Keep them separate. They should only connect at the star ground point in your PSU.Dualflip said:...or is it meant to have everything on the chassis isolated, till the last point where everything joins together at one point?
Dualflip said:Thanks, ive been reading the Rane document that Jeff posted, thanks for that BTW, just have one question. I had the belief that every time that chassis gnd joins signal ground it must be done at one point only, therefore it is why everything goes to a star ground. Rane strongly recommends that pin 1 be connected to chassis at the point of entry, i understand that BUT isnt that point at which the ground gets connected to the chassis also be connected to my star ground with an other wire?
Another question, by terminating pin 1 to chassis at the point of entry, doesnt it leave the internal audio wiring with the shield disconnected from ground thus making it more sensitive to EMI such as the one emmited by a power transformer inside my enclosure for example? im talking about the cable that goes from my PCB to the XLR connectors, which so far ive been keeping the pin 1 or shield connected from the XLR all the way to my PCB signal ground...
nearly all modules I'm aware of have the top/back stand off mounting hole routed to this pin 1.ruckus328 said:Pin 1 - "Chassis ground" - My question is is this typically ever even used for anything? If I have board standoffs/mounting holes mounting the boards to the metalwork, should I ground these standoff points to Pin 1? or should I just rely on the front panel mounting to the rack to sufficiently ground all the metalwork?
nearly all modules I'm aware of have connected pin5 and pin13 to the same ground.ruckus328 said:Pin 5 - "Common Ground" - Assuming this is audio ground. My question is, Is Pin 5 on each channel tied together on the backplane PCB? Or is Pin 5 on each channel kept segregated from each other and tied together at the Power Supply? The reason I need to know this is, what should I do if I'm dealing with a stereo system (with seperate L & R grounds, but also common ground points for both boards)? Seems it starts to get tricky when dealing with this, as how do I address the common ground points?
Should I route them directly to Pin 5 and rely on the backplane to tie them together?
Pin 13 - "PS Common" - Not quite clear what this is used for. My assumption is it's a seperate ground point kept isolated from Pin 5 and tied to Pin 5 back at the Power Supply. My guess is I would use this for things like relays, LED's, etc - basically anything I don't want touching my audio ground.
Yes this is true. I had some mute pops on the VC528 until I fully separated the relay ground to use pin 1. At the same time, I also now use pin 1 for LED ground. And like Volker says, the top rear standoff always connects to pin 1 Chassis ground on my modules as well as all API modules I have seen.[silent:arts] said:...nearly all modules I'm aware of have the top/back stand off mounting hole routed to this pin 1.
as far as I know Jeff was unhappy with some relay switching plops and solved it routing relay ground to chassis.
this information is unconfirmed, may be Jeff chimes in ...
[silent:arts] said:nearly all modules I'm aware of have the top/back stand off mounting hole routed to this pin 1.ruckus328 said:Pin 1 - "Chassis ground" - My question is is this typically ever even used for anything? If I have board standoffs/mounting holes mounting the boards to the metalwork, should I ground these standoff points to Pin 1? or should I just rely on the front panel mounting to the rack to sufficiently ground all the metalwork?
OK, so Pins 5 and 13 are tied together on the backplane PCB, but where? Do they connect together right at the cardedge connectors? Or do they stay seperated and tie together at the PSU connector?[silent:arts] said:nearly all modules I'm aware of have connected pin5 and pin13 to the same ground.ruckus328 said:Pin 5 - "Common Ground" - Assuming this is audio ground. My question is, Is Pin 5 on each channel tied together on the backplane PCB? Or is Pin 5 on each channel kept segregated from each other and tied together at the Power Supply? The reason I need to know this is, what should I do if I'm dealing with a stereo system (with seperate L & R grounds, but also common ground points for both boards)? Seems it starts to get tricky when dealing with this, as how do I address the common ground points?
however, I'm playing with a tube module using DC/DC converters, my plans are to connect all audio grounds to Pin 5 and all PSU related grounds to Pin 13.
the 511 backplane has two ground planes, one is pin 1, the other is pin 5 and 13.
normally both end at a start ground point in the PSU case.
hope this helps
jsteiger said:I have started adding a 10R between pin 1 and my local module ground plane. For me this is 2 fold. First, it ensures local isolation on my card. Second is that if some user or other rack manufacturer has pin 1 floating in their rack, I still get a ground connection on pin 1. This is not optimum and should of course never happen but never say never. I do remember of reading that API had a batch of 6 space racks that pin 1 was floating. Maybe an error somewhere and maybe BS but I did reading it somewhere.
thermal pads at the card edge connectors directly to the same planeruckus328 said:OK, so Pins 5 and 13 are tied together on the backplane PCB, but where? Do they connect together right at the cardedge connectors? Or do they stay seperated and tie together at the PSU connector?
yesruckus328 said:And if I'm understanding correctly, you're saying you'd typically tie Pin 5 and 13 together on the module?
you don't have to do this. but having a single ground plane makes life easier.ruckus328 said:If so what is the point to doing this if they are tied together already on the backplane? This would create a loop.
you never know the chassis the module you designed will live in ;Druckus328 said:You lost me here. If you're local plane is connecting to Pin 5/13 (which all the other modules will be also), then how does adding a 10R resistor between it and chassis ground get you any local isolation? Maybe I'm misunderstanding.
[silent:arts] said:thermal pads at the card edge connectors directly to the same planeruckus328 said:OK, so Pins 5 and 13 are tied together on the backplane PCB, but where? Do they connect together right at the cardedge connectors? Or do they stay seperated and tie together at the PSU connector?
and it doesn't create a loop, it just uses two connections from one plane to the other.
if this creates a loop, no ground plane would exist ;D
Same goes for phantom powered mics![silent:arts] said:you never know the chassis the module you designed will live in ;D
if it is a chassis with pin1 unconnected Jeffs relays wouldn't work anymore.
