livingnote
Oh - it's "Gleitzeit" through approx. Saturday morning.
cool. have to prepare some plug-in files ;Dlivingnote said:Oh - it's "Gleitzeit" through approx. Saturday morning.
both ways worked fine. I did assemble one prototype PCB completely without having any metal work, and I had no problems to screw the metal down.briomusic said:1. how did the screwing-in-of-XLRs FIRST work for you? easy to line up the pins on the PCB afterwards? or would you prefer the sahib-one-pin-solder approach in hindsight?
the XLRs we use have pin 1 connected to the chassis. haven't measured yet if this is enough connection since it is powder coated. however I would do the pin 1 to chassis link.briomusic said:2. on the grounding scheme: what if a mic pre-amp needs to provide phantom power? is it enough to have pin 1 on the chassis or does it also need to be connected to PSU ground? I understand removing pin1 from the chassis is not possible with the included XLRs?
[silent:arts] said:important is a hot enough soldering iron...
will add some with your PSU order ;D ;D ;DRedNoise said:Where should I claim for the missing Gummibärchen ??? ;D ;D ;D ;D
