In the US (and likely elsewhere), old concrete often gets reused. Way back when my neighborhood was still poor, there was a spot nearby where old concrete from commercial projects was delivered and crushed to bits. Rebar was removed & recycled, and the smashed concrete itself was put to use in various ways on new construction projects. While it may not dispose of concrete, it does put old concrete to use in new projects.
That method has now been refined to combine it with steel production. The end result is steel, cement and slack that's perfect for making concrete.
Besides, our concrete doesn't last as long as the Romans' concrete. That's being studied but I've not seen results. Maybe I've missed them.
Concrete is far less dangerous for the environment than asphalt. Emissions from ICE cars have been optimised so far that emissions from roads come into sight. After that brakes and tires come into the picture.
It's never as black and white as in the title of this thread. It's true only if you refuse to look at the successes. It's also true as in "solar isn't the perfect solution every time".
And sometimes, even the best managed projects go bad. That's why you want an overview...
One things for sure , solar panels contain a cocktail of nasty substances , sooner or later that problem is going to have to be to be dealt with .
Im not party to the contract these people signed , but I do know that part of it said the land will never be fit for agricultural purposes again and is prevented from ever being used for that purpose .
What substances would that be?
According to Goolge, "cadmium telluride, copper indium selenide, cadmium gallium (di)selenide, copper indium gallium (di)selenide, hexafluoroethane, lead, and polyvinyl fluoride.
As an engineer, you will probably recognise the first few as semiconductor dopant. Is that a problem?
Hexafluoroethane is a "safe" gas. Non toxic. Not very dangerous to the environment.
Polyvinyl fluoride is a typical transparent film, used in millions of other products nobody balks about, like cars, trains and planes. Yes, it's a plastic, so it's dangerous to the environment because it doesn't break down easily.
Veoila, to name just one, already operates a few plants for solar cell recycling. There are no problems technically, but very little of the recyclable materials is worth a lot. We'll probably see a tax on solar panels to finance recycling. That worked perfectly for batteries, so I don't see why it wouldn't work for solar panels.
ATM, a staggering 99+% of batteries is recycled over here. The remainder is mainly from hillbillies who still dump their used car battery in the woods. And phones lost in the river and ponds. The last one is growing, unfortunately...
