Look guys, the gentleman is asking for design inputs, all it is going to cost US, the onlookers, is a bit of time reading, with interest, and supplying ideas and suggestions.
I say Gettestudios go all the way for it!
I built myself a 12in 4 bus stereo out from components taken from some various retired consoles in the mid 80s. I still have it and it never got <finished> in the sense that I learned and experimented so much from it!
You have my support, interest and admiration.
But as some already suggested, there are a few first step to be taken before committing metal and silicon to the project.
So here is officially my first input toward your project.
Here is some suggestions about how I would go about it.
- buy some tabloid size paper to draw, sketch, doodle etc... 1 tonne seems a reasonable starting quantity!
- Get and learn to work with a mechanical CAD software. I have no recommendation but the guys et the shop here swears by SolidWorks
- Get and learn a good schematic-PCB software I use Protel 99 ( about 3K$ at the time) but I have switched to KiCad, an amazingly good soft and FREE!!
With these tools you will be able to THINK your dream and put it to paper.
When I start designing a new project, I spend a good deal of time just <using> the thing in my head and on paper. From these thinking and bull sessions a certain consistent pattern will emerge. Think of how you want to go about it. Forget schematics and technology for now, think about how YOU want to USE the thing.
You have to decide beforehand about things like:
- In line or split configuration WHY?
- how many AUX busses and WHY?
- what kind of EQ/shelving/peaking ? WHY?
- how many bands of EQ? WHY?
- Dynamic process on each channel (Gate/compressor/expander/limiter etc)? WHY?
- how many busses? WHY?
By now you get the pattern... you check what the others do, you dream up your own version and then you auto criticize it until you are somewhat satisfied.
DON't try to solve all the problems at this stage! In fact, don't try to solve ANY problem at this stage, but DO identify them!! (Let's see, hmmmm.... placing the machine control here seems reasonable, but then I can not get easy access to the intercom/master monitoring section... problem! )
Now go ahead, buy some plywood and MDF and make an actual size mock up of the board and draw with a felt pen the actual layout of it to check on your ergonomic issues and see if it suits you. At this stage moving thing around is easy. And the size of it might makes you reconsider a few items to the agenda....
Now try to identify the section that you think will be the most troublesome to design/test/build and tackle this one first.
SChematics, experimentation, prototype etc.... until it works satisfactorily.
In my case, the EQ is my beef!
And keep us posted... this thread could be your journal
I whish you all the luck, and I will help you in the capacities I have.
Luc
