Yes on the channel which gives the +7dBu output turn RV1 on that channels sidechain slightly counter clockwise intil the output drops to +6.5dBu.That's right ! Which trimmer?
on SC board? An only trim the board that gives higher output?
Sorry actually I measured too fast :Am I right if assume that channel which originally measured 3.89V gives the +7dBu output?
You can trim or try different tubes. I would probably just adjust the trimmer.
I'm sending the sine wave through the test oscillator of logic with UAD interface and measuring the voltage sent on each channel to be 0.245VAre your input levels being sent from the dac or wherever calibrated?
Though now the 1db LED is lit on the board I had to adjust, I saw your post about adjusting the resistor for it... but I mostly work by ear so that's fine
I thought R6 was supposed to be changed to 10k?Another option is to add 220k resistor parallel to 13k R6 on the LED board. That would make the resistance approximately 12k.
There are two versions of the LED board out there. The original LED board did not have a trimmer and the new revision has a trimmer for the 1 dB led.I thought R6 was supposed to be changed to 10k?
Got it! Thank you!There are two versions of the LED board out there. The original LED board did not have a trimmer and the new revision has a trimmer for the 1 dB led.
R6 is 10k in the LED board version which has a trimmer for the 1dB led.
The original LED boards don’t have a trimmer and in some cases the R6 needs to be changed from 13k to 12k.
Great job, very neatly built. Did you use 6SS7 tubes?Here are some pics from my build.
Yes like you mentioned in one email, sourced them from helsinki, they were a cheaper option than 6sk7 which they also hadGreat job, very neatly built. Did you use 6SS7 tubes?
Would this mean a smaller current ac/dc brick could be used in this case?Hint for anyone else building this too. 6SS7 can be used instead of 6SK7.
Any other possible candidates? Would be nice to try different ones![]()
6SS7 does have only 150mA heater current where 6SK7 has 300mA. But I wouldn't want to have a wall wart which has only enough power to supply 6SS7 in case I would want to use 6SK7 later.Would this mean a smaller current ac/dc brick could be used in this case?
