Here are some suggested modifications for mastering use.
It's probaply best to explain the modifications here too. The idea is that you have unity gain when the gain rotary is at middle position. From the middle position you can adjust the gain between -5.5 dB and +5.5 dB in 0.5 dB steps. The sidechain steps are changed to 1 dB steps and a switch is added to get to get 10 dB more range from the 12 step switch. Step 12 (fully clockwise) is always off position.
U9 and U10 are changed to INA2137. This is related getting the gain to unity when gain is at middle position. R43, R44, R45, R46 are changed to 330 ohm. RT1 and RT2 with the 1k resistors are added to make make and adjustable U pad for the outputs. These trimmers are used to adjust the gain to unity when the gain rotary is at middle position. This also makes it much easier to balance the gain between channels because there's no need to mess with the bias trims to balance the gains.
R39, R40, R41, R42 are changed to 1 ohm to make sure the +15V and -15V voltage doesn't sag to U7, U8, U9, U10, now under heavier load.
I do not recommend doing these changes for any planning to use compressor in tracking or perhaps in a mix bus. Potentiometer sidechain is more than adequate for plenty of uses. I do personally prefer
this coarse stepped attenuator to a gain pot.
Edit: Updated version of the mastering modifications.
