kquick
Is there a BOM available so I can start sourcing parts?
dmp said:The sample arrived today of an A-Range design I've been working on... going to build it up and try it out!
It has the mic and line amps with switchable full EQ. I included a phantom and pad switch on the left for the mic input. I used grayhill switches for reliability and ease of assembly and included components to use all 6 positions available on the grayhill in the EQ if desired (going from 4 freq to 6 freq per band). The EQ faders have dual footprints for using different pots. The EQ has high and low pass, low, mid, mid high, and high, just like the original. An output fader is last on the far right. All in 1U enclosure. No 500 series for this one!
kquick said:Does any one have a legible A range schematic they could share?
I have a hard copy that needs to be scanned. Just have not had time yet. I will post to the group email account when done. It's certainly not perfect, but with the others around, one can figure it out.
