What you need to do first is scope the waveform from the piezo pickup. Now you might want to build a voltage divider resistor string to not load down the piezo pickup when it operates into a >3 meg load OR just hang a scope probe on the piezo output not connected to anything else and hit the bars and note the peak to peak output voltage. Or use Scotts circuit and math before the scope
You might be generating more voltage than from a guitar etc so you will need to check
This is so you can DESIGN for the output voltage of the pickup. You will need to know the input and output headroom to not clip.
Using a 12au7
-4 grid for input headroom
300 VDC B+
3.3meg, 10meg, 22meg what ever sound good input resistance
lower voltage fil for more like a tube microphone input resistance
Looked at the 12au7 curves I found on the web I picked the resistor values 510K and 8.2K you might want to cap bypass the cathode resistor. 510K and 8.2K are a first try values under heating at 5.8VDC and lower plate current.
If the distance between the circuit and the tube amp with a 1meg input is short you should not need a CF. Now if you want to use a direct coupled CF you might need to raise the heater voltage above ground.
HV mosfet as a SF, be careful with the power up and the gate to source voltage breakdown voltage.
Scotts circuit being a SF and having a voltage divider should work very well. I do have a question about it why is there a input cap and not just two 4.7 megs top or middle node switched to the gate when using a piezo? Does that low of a gate voltage cause dielectric stress in the piezo element that changes the sound if direct coupled?
Miller cap will have an effect look at a km84 circuit note the 4pf cap drain to gate (and the pad cap) that works with the capsule cap and the open loop gain of the fet stage and the transformer ratio to set the gain.
The summed up piezo pickups cap divided by the plate to grid cap and the open loop gain of the tube circuit. If you have to much gain maybe a cap plate to grid to work it more like a charge amp.
Using a 12au7
300 VDC B+
