Matador
Here is the updated schematic and ground topology:
http://www.musicalsparks.com/images/6sn7_preamp/6SN7_Mila3_V4.pdf
Matador said:What tipped me off is that I listened carefully through a set of headphones before I even activated power to the box (with the exception of the currently-external heater supply). I could hear a faint hum even before I powered anything on. A clip on the secondary of the output transformer leads shows a slight 60Hz hum signature (according to the frequency counter on the scope). I do not see this pre-output transformer though.
Here is an MP3 file of the hum along with the "wind" noise that I'm getting (you can hear it come in even before I thump the mike a few times to make sure I'm "live").
Matador said:Here is the updated schematic and ground topology:
I did however find something interesting: when I placed the top cover plate on the chassis without mounting screws, it rattles! When I placed my hand on the chassis, I can feel a faint 60Hz vibration. I'm wondering now if there is a mechanical coupling between a transformer and the tube sockets. I did a pencil test, where I strike the side of the tubes with a pencil while listening through headphones: there is a loud PLINK sound when struck (indicating these EH tubes aren't stellar from a microphonics point of view).
Next I will try rubber isolating the transformers and tube sockets. I'll also try wearing some welding goggles and physically holding each tube to dampen vibration.
All in all I think I'm planning on moving to an external power supply based on Gyraf's G7 design. That will also solve the dropout problem I have in the heater regulator since my current Hammond power transformer only have 6.3V AC secondary windings. If I move to a 120V:9V then to a 9V:230V then my heater regulator board has more voltage to work with.
Any suggestions for good quality multi-conductor cable? I need:
1) 300V supply
2) 6.3V supply
3) 48V supply
4) Ground
I'm thinking a 5 conductor XLR jack / wire combo so I can use two wires to carry the heater current.
Nice thing about an external supply is that I can power many different circuit topologies / preamps with a single supply design.
ruffrecords said:External power supplies are a great idea for all the reasons you have thought of. I use an 8 (so I can double up on the heaters if necessary) way cable and 8 way Speakon connectors. I use military grade screened cable but it is very expensive. Might be better to make your own.
letterbeacon said:ruffrecords said:External power supplies are a great idea for all the reasons you have thought of. I use an 8 (so I can double up on the heaters if necessary) way cable and 8 way Speakon connectors. I use military grade screened cable but it is very expensive. Might be better to make your own.
Do you have a link to the military grade cable at all?
Matador said:I already stripped out all of the phantom and heater regulator circuits from the chassis just to experiment - no change in noise / hum levels.
The power transformer is indeed a guitar amp transformer - a Hammond 269GX to be exact. It's about 50 VA overkill but it's what I had on hand that was within reason for the voltages I needed.
