https://www.snapeda.com/Can you please tell me where to find grayhill footprint? did you draw it whit kicad footprint editor?
https://componentsearchengine.com/library/kicad
https://www.ultralibrarian.com/
Sign up and download what ever symbol, footprint, or 3D .stp file you need for your design. Just make sure you double check measurement with the component datasheet because there could be discrepancies. Also, you may want to adjust pth pads for mechanical parts to be larger.
For instance the grayhill switch footprint I downloaded had the pin spacing 1.905 when the datasheet clearly states 1.91 spacing. I had used the 1.905 spacing on my first run and the particular grayhill I had was hard to fit. The pin spacing has a tolerance as well of .13mm. The footprint I sent you has the corrent spacing with .60pth. so you can run a .325mm trace between pads.
