Hi Spence as I said Im in a little over my head with power supplies but yes I see what your sayingunder load it will drop but Im not sure how with this power supply it may not be same as say Maxes MK47 power supply which does work like that I think mine measures way above 160V but under load drops down to 108V if I remember correct 3V over & your mic will only need 105V for plate drawing less milli amps than a real U47 or MK47 which will be drawing current to heat the filiment as well as plate... to do the maths you will need to look at EF80 data to see how many milla amps the plate needs ...... what you could do is build power supply as is build the mic measure the resistance of the mic itself then get a resistor to act as dummy load connect across your power supply to make sure the load brings voltage down far enough.... from what Im told & experiments the tube are very forgiving... if voltage not right adjust the resistors still using dummy load before trying with the mic....
Take a look at MK47 power supply has built in dummy load resistor 2k3 5Watt to simulate the mic being connected, I guess 2K3 5watt resistor would be ball park for your mic
I think the heater supply will be fine will supply 6.3V or less, regarding underheating as Pip says there ton of info on it here & google a lot of classic mics under heated their tube, M49s AC701 between 3.8V 4.2V Maxes MK49 6028s are underheated to match a V14 ... 5840 mini tubes usually 5.7V instead od 6.3V
Found this in another forum ....The U47 underheated its VF14, and Oliver Archut recommends underheating an EF14 to 5.05V (should be 6.3). From what I've read, I believe underheating can change impedance characteristics, but I'm a little out of my depth there as far as understanding the finer nuances of tube behavior outside normal operating range.
