find quite contradictory information:
here says the EF12 is not suitable for a U47
http://www.moxtone.com/mU47_U47_part3.html
AEG use them and say that both EF12 and EF11 are perfect?
http://microphoneboutique.com/product/aeg-moscow-mkl-49/
found a diagram
You could try a TL783 power supply for B+ or one with a capacitance multiplier. A voltage multiplier with a lot of additional RC filtering would also be conceivable.I’m interested in building another two psu and wondered on other options which could work, anyone have any other ideas?
Sort of, you'll probably need a series resistor in front of the TL783 to get rid of some voltage. Additional RC filtering after the regulator would also be better, essentially like Jakob does in the G9.This could work
Edit: what is the function of this 22k 5Watt resistor?
Makes sense, a bleeder resistor for the capacitance. Makes working on this circuit less excitingDischarging the capacitors between the bridge rectifier & regulator? And, via the antiparallel diode with the TL783, also the capacitance after the regulator?
Some do it with shotkey diodes and low drop voltage regulators, I do it with a voltage doubler and additional filtering. Check this out, you might get some inspiration from it. (this method is more flexible IMHO)Just need to know if i'll be able to use the 6.3vac for the H+?
I am not an expert for Tl783 circuits, I would add a little resistance in front of the 100uf cap on the output side of the regulator to get some extra filtering.for the 170Vac B+ side would this be ok?
