Do you "All"(Korg, Khron, Paul) also believe that this little electrostatic speaker effect that you agree causes mechanical movement of the diaphragm opposing the input signal, has zero measurable or audible effect on the sound besides purely passing though electrically?
No.
None of us thinks that. All of us think that it will have a measurable but
smaller effect (than the straightforward electrical cancellation), which may be audible.
AFAICT we all agree that the effect exists, and should be measurable, and may be audible.
We all think that there will be an electrical cancellation effect which is consderably more efficient and therefore much bigger and more audible than the diaphragm-motion-inhibiting effect.
We think that the high-pass filtering effect is
mostly due to electrical cancellation of the signal being fed back from the output to the input, and some smaller effect is due to inhibiting the diaphragm motion with the electrical back pressure.
That raises interesting questions.
One question is how important the additional effect (of reducing diaphragm motion) is, as opposed to rolling off the bass in other ways, like with normal EQ.
Can you get much the same total effect just by using more electrical cancellation, with EQ? I don't know.
Are the different effects frequency-dependent in different ways, so that they sound different? I don't know.
What happens if the amp clips and feeds back the clipped signal (low passed and 180 degree delayed)? I don't know.
