dawsonaudio
I’m kind of figuring this out as I go so I’ll figure out a better grounding scheme, Could you recommend a reference? Thanks for your help here.
Ian's grounding doc is a great read.dawsonaudio said:Thanks for the info. I will try to address those issues.
mrclunk said:Ian's grounding doc is a great read.
http://www.ianbell.ukfsn.org/EzTubeMixer/docs/EzTubeMixer/SimpleMixer/grounding101v2.pdf
I built a 610 clone and didn't have any probs with hum. If you're still stuck after reading that i can open it up and see what i did but sure it's just standard star ground.
Did this ever get sorted out? Would be interested to know your thoughts on Cinemag vs UTC output in this circuit. I really enjoyed the UA plug, now I'm itching to build one.dawsonaudio said:Just coming back to the preamp build.
I appreciate the information on the reading materials. I've browsed some of the 'Building Valve Amplifiers.' There's a lot there.
I'm a little confused as to why I'm not able to get this preamp working without noise and hum. I've eliminated the eq section entirely. Bypassed the 250k potentiometer (added a 250k resistor from pin 2 to ground/ .2 cap going to pin 2)but still have an enormous amount of hum. There is some kind of ground loop happening....? The preamp is working, just with hum in the background...It also sounds just a touch thin. Not a lot of low end, but that could be just that I'm testing using a 57. Still, it seems a bit on the thin side.
I re-star grounded the preamp at two points, input valve and output valve. Then they both separately connect to power supply cap ground.
Maybe it's my layout? I've built a couple of la2a's and never had this issue. Maybe the output transformer A25's ground shouldn't be connected...? Any ideas? Maybe I should I use a turret board instead?
Nate
Gridstopper, is the Hi-Z input jack isolated from chassis or? IOW, do/did you have a double earthing going on?
What I'd try is, making the ground point right at the first 12AX7 stage be the ground that is connected to chassis. Have no other connection from B+ ground etc to chassis/Earth. Then use an isolating 1/4" jack for the DI input.
Short cable runs from DI and mic switching etc. to that first 12AX7.
Alternatively, if using a non isolating jack, use a telescoping shield with shield connected only at the jack end.
However, I think the first way with isolating jack would be less circuitous in getting a good ground reference for both mic and Hi-Z.
Hi John, and all..A couple of us went to Neil Young's place to see it. The desk had originally been @ Wally Heider's.
ok! one last update(sorry to spam haha)
so i probbed through the circuit and the hum only appears at the grid of V2-b, the one that is being directly fed by the optx. getting closer...lol
