[quote author="StephenGiles"][quote author="StephenGiles"]Where does ambient noise come into the equation I wonder?[/quote]
All very well to ignore my question, but a combination of bad ears and general ambient noise can surely fool the listener into hearing noise in a preamp that may not be there can it not?[/quote]
Not sure what you are trying to say with this, so please forgive me if I've misunderstood something. Never ignored your question, but my studio is designed with great care for very low ambient noise, both acoustically and electrically. Computers are running on a separated power with galvanic isolation from the audio equipment, and the audio power has its own dedicated and clean ground, separated from the electric company ground lines (which can contain a lot of noise in some cases)
In this case, by turning off the other pre-amps a new noise source was introduced, which also showed up on the graph. You might call it a design error in the pre-amp. There should probably be some kind of dummy loading when the unit power button is in the off position. It has not been there before, since I've always used all pre-amps powered on. Initially I was worried about having these switching PSU's, and now I might indeed have to find another solution.
And my ears are fine, thank you.
Martin
