Spencerleehorton
Just making a note that the univibe current draw is about 35mA, 0.035A
I’ve reboxed this original circuit univibe, I’ve put in several mods, speed mod, changed middle 1uf to 2.2uf and changed 4.7k resistors to 1.5k. Now it’s an acceptable fast speed and nice slow speed.
I’ve changed the 47k on the input (after the first 22k) to 2.2M and changed the 3.3k to 7.5k on the 3rd transistor collector and now have plenty of volume between effect on and off.
True bypass and I have also put in the 50k pot with 68k on each leg with the wiper going to the chorus/vibrato switch, taken out the two 100k resistors.
The problem I’m having is setting up the bulb and the LDR so that the effect is more prominent, on chorus it sounds nearly there depth wise but on vibrato on slow speeds the effect is really difficult to hear.
The other problem is I can hear the robot the bulb, almost like there is an earth problem?
And help on getting the effect more prominent and getting rid of the bulb noise would be appreciated!!
Here is a good link to schematics etc
https://musikding.de/docs/web/univibe-ForumVibe-final.pdf
may be start by painting the inside of your Kinder egg dome Flat Back to minimize reflected light?"the effect is more prominent"
I've Got a Moen Shaky Jimi which has brought the concept into the 21st century, it uses LEDs and LDRs, one widely used "mod" (to achieve the goal you list,)is to Light shield each individual LED-LDR PAIR. so there is no cross talk with other LDRs in the circuit. Black electrical tape being the "Mod"
I thought the idea was to have as reflective surface as possible inside?
Please let us know what changes you end up making to the madbean versions.I now have 4 univibes but only one working how I want it too which is my vibe A, pretty sure this Shin Ei vibe will be fine, the other two mad bean versions need some attention to get to be as good as this vibe A, now I feel I have all the info need to get them all working correctly.
I heard mention of it, but no detail. It's something I've wanted to try out for a long time; see how it does with envelope following and different control shapes. Sorry for the tangent.No I haven’t? Is this something you know about?
I'll give it a try with vactrols, thanks kindlyMake the dual-pot a dual-optocoupler and control the LED current.
