chrispbass
The story is not quite over, but more later.
Thanks JohnSounds like a win..... Good job.
Some call that ingenuity.a good dose of stubbornness for good measure
Persistence combined with the collective wisdom and experience of this remarkable forum.
Is it usual to use the volume buttons to get to the other menus?but after 2 or 3 presses it invokes a sub menu.
Old Apogee Rosetta switches will jump over several selections with one push. Very frustrating.Possible switch contact issue - bounce/resistance?
I'd guess the contact issue since you say the remote works fine but the accessing sub menus is kinda weird if it's not supposed to have that function?
Is it usual to use the volume buttons to get to the other menus? ,,,
For sure. But if the button isn't supposed to have that function, it would be weird if it acted that way..On some devices, amateur radio transceivers for example, buttons have multiple functions. For example, a short press may lower volume, while a longer, lingering press may bring up a MENU
I have no idea what exactly is going on and since the remote works, this seems more of an academic pursuit.For sure. But if the button isn't supposed to have that function, it would be weird if it acted that way..
I guess JR's description sounds like a possibility if not...
This sounds like maybe it is using an ADC to only need one button to sense multiple different buttons:MCU push button switches often use weak internal pull-up current sources and switch closure to ground.
it just seems (as far as I could tell) to be a resistor ladder(divider) with each switch connecting to ground, but haven’t traced it out.
. . . I’ve now got it all back together in the case and it was a nice moment to pop a CD in and fire it up properly as I’ve just been using headphones whilst on the bench. . . .
Oh , no old man . . . you cannot quit now! We have only just begun raking this one over the coals - we are not even close to reaching overkill . . . um . . . er . . .
OK, never mind. Glad it you got it working again! Cheers. Take Courage. James
