I’ve got 4.4V on the 22uf going to pin 40
Which should also go to pin 42. So where is the 8V coming from?
The PT2037 does not have a bipolar supply, so likely the inputs and outputs have to be biased to half of the positive supply.nearly every input/output pin is reading about 4.45V!
Good point CC…thanks.The PT2037 does not have a bipolar supply, so likely the inputs and outputs have to be biased to half of the positive supply.
It could, or it could suggest a bad solder connection.Good point CC…thanks.
I’m still in the dark as to why the DVDD is so low at 1.3V. I pulled off the FM module and found another 3.3V regulator underneath but it’s working ok. I re-checked the DVDD voltage to the analogue controller with it removed and it had gone up to about 1.43V.
As Thor mentioned previously, this chip is the likely culprit, but if faulty, would it likely pull down DVDD to such a low level?
I wouldn’t have thought there is much too a 3.3V psu, especially if using a regulator.
Can you trace the VDD back to a 3.3V regulator? A) What is the voltage at that regulator? B) with power off what is the DC resistance between the 3.3V regulator output and the VDD power input pin?
I just looked at the data sheet and the damn thing does not say what the DVDD voltage should be?
That does indeed look suspect. A burnt via or trace dissolved (by what? leaky cap?)
Fixable, but what caused it, dear Watson, what?
Raahahaa! Outstanding! Good work!
Lucky but good job.
Thor
