V475 translation + summing network
I think that's time for refreshing this. Nothing from Hufe, but i just finished auction on German E-bay for two V475-2 :wink: I hope that modules are in good shape, and really need some info about pinning :green:
Also, does somebody have idea for skipping low-pass ft. I would like to hear this baby over 15khz :cool:
No, that´s a typo. :wink:
Anyway, here is the schem of the C version, as promissed:
http://hps.infolink.com.br/rafafredd/V475-2C_schem.gif
It would be nice if someone can mirror this image, as I had to make it big to make it readable, and I don´t have lots of space on my server, and I´ll probably delete it soon.
PS. Ethan, can you turn the autoresize on again? It worked nice for weeks...
Cool, and here's redrawed and optimized :wink:
http://img187.exs.cx/img187/6730/v4752cschem8xt.jpg
Hi People,
Now I`m the proud owner for a neumann V475-2 module :grin:
I`d like to build a 16 channels summing box with l-c-r pan swithes and maybe volume controls (input attenuators) for each channel.
The module I own is a v475-2 without letters (not A, B or C versions) and I just have a pinout and some data I`ll try to scan and post here.
Trying to read german language betwen lines, it seems that the v475-2 version don`t need the Rg resistors, I think the gain is set by a couple of trimmers in the board. That could be useful for anyone with an A, B or C version trying to add a varible gain pot instead of fixed resistor gain.
the pinout is similar except for the Rg(not used) and +24 for channel2 is located at pins 3-4 instead 29-30 as the other versions.
Well, now I (we) need an schematic....
:!: Anyone?
Synthi.
:razz:
Check here:
http://img.photobucket.com/albums/v321/synthi/v475-2/v475-2-1.jpg
http://img.photobucket.com/albums/v321/synthi/v475-2/v475-2-2.jpg
http://img.photobucket.com/albums/v321/synthi/v475-2/v475-2-3.jpg
http://img.photobucket.com/albums/v321/synthi/v475-2/v475-2-4.jpg
Now can anyone that can read german translate the diferences between v475-2 and V475-2A?
Also check the diagram in page 4 for adding a 15K pot to a v475-2A for remote gain control!
Best Regards,
Synthi
[quote author="synthi"]:razz:
Synthi[/quote]
according to description the v475-2 has no external connection for feedback adjustment (Rg).
steff
Thanks steffen, I noticed that. Also I think the 475-2 could have extended frequency? the data say >= 8dB @50Khz for 475-2, and >=20dB @40Khz for A version (?). Internal trimming is +-3dB for the 475-2 and +-1,5dB for the A version. Otherwise seems the same than the A version with Rg=6.2K
Synthi.
At last I'm holding my V475-2 boards in hands. I didn't try to connect , but will be nice to cancel LPF and extend this little beast for full range bandwidth. I understand for V475-2b that this filter is separate board and "removing"opens to 200khz, but 475-2 has no separate board and I'm not sure what to remove. Any comments? :?
hi there everybody from a newbie! :grin:
I´ve just got me a v475-2 (no ABC) and found your thread.
>Rafafredd:
did you succeed in building your summing amp?
did you include symmetrical panning?
if so, how does it sound?
>Synthi:
how did you wire up your L-C-R inputs?
>everybody else:
-any hints on the L-C-R wiring?
-on this card, even though it does not provide external output gain setting, what would be the way to do so (with switchable resistors maybe?)
thanks a lot for your valuable contributions so far!!
hang 10 :thumb:
[quote author="Moby"]Thanks! :wink: :thumb:
BTW, have you ever heard how sounds 475-2?[/quote]
I must hear them every day, we still have more then 20 Neumannn Mixers at work :roll:
Ronald Prent told me at Live Aid that he likes the Neumann Sound a lot :green:
Welcome to the group hang 10!
[quote author="hang10"]any hints on the L-C-R wiring?[/quote]
I decided to go the easy way, only L and R inputs, wired the same way like Neumann did it:
while I have the 475-2B I decided to have gain switched (-6, -4, -3, -2, -1, 0, +1, +2, +3, +4, +6 dB).
still waiting for the case :mad:
Nice :wink: Did you connected switch as the variable Rg? What values of resistors you calculated for gain? :roll:
