There might still be output signal on the XLR pins even when the USB-C plug is connected, so if you can find a socket (or two for at least two pins) small enough to fit into the male XLR pins when also the USB-C plug is plugged in you could route the output to a 3.5mm jack using a DIY cable. Also Rode might come with an adapter cable later.There's no 3.5mm jack on the 5th gen NT1. If you're planning to use some sort of USB C to 3.5mm adapter I have no idea how that would work going into a camera, or even if the mic will work on plug in power.
