I'e tried R1 & R2 with 6.8k as you suggested but B+ was reaching 212V, and my goal was to have it around 210V. So I tried 9K resistors and that provides the 210V.
The difference between 210 and 212 is marginal in terms of operation, however, conceptually, there is a significant difference: in the latter case the zeners are doing their job (more or less, I admit), and in the former they don't.
But do we really need regulation here?
Maybe, if only for the reason I expose in post #245, which is probably not relevant to you, but is for a manufacturer. This is assuming the manufacturer knows what they're doing...
U67 PSU's are not regulated and that doesn't seem to be a problem.
At the time, Neumann did not have to face the numerous regulations we have today.
I know the Zeners are there with the intention of providing regulation at 212V, but how important is that?
I don't know, I can only guess (maybe wrongly
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
, I may completely ... change their placement
I could easily do that if needed.
Not so easy because you would have to change the zeners for a higher value, roughly according to the voltages you would measure on the various caps., with the values of R1 and R2 changed.
For example, the one before last cap would see a voltage of about 217V, so you would need to increase the voltage of the zener string by the same amount.
You say you replaced them with 9k. Am I right in surmising they're actually 9.1k?
