I have 10 pounds of 75 EI coming in next week, along with U brackets.
(Build your own 1166, 4 dollars a pound for steel, 25 cents for a bracket, and 25 cents for a bobbin, you supply wire, Ken - Ram Sales 1-818-997-8057- he will take a check, but you have to wait- no min order)
I have the transformer 99 percent designed, but the last 1 percent is killing me!
I have the core, I have the flux, I have the turns, I have the wire size, I have the leakage inductance down, but I can't seem to get the capacitance down to a tolerable level.
The problem is that I am fighting two variables here, the wire size, (remember, I need to feed 10 ma to the 707's, use 20 ma safety and low dcr) and turns. The bigger wire leads to more capacitance, (imagine winding with copper the size of a 2 by 4, compute your capacitance).
And the high impedance pri means many turns and thus capacitance. I found out that the disk method (Oliver type) does not do good with stray C at higher ratios, so I am not going to wind it like that.
You can not wind bi-tilar pri to get good balance because capacitance is to high with that many turns. You can cancel capacitance by putting half of winding under the cathode, but this reduces gain of output stage due to NFB.
Sheesh, no wonder nobody makes a 40K:600 at 10 ma balanced!
But I think I can get you a 3 bd rolloff at 40 k hz if that is adequate.
Low end will be fine due to many henries of un gapped core. (push pull)
cj
