metal filament, a mix of plastic & metal powder
It sure can be done.Sounds like the perfect job for a 3D printer. You can get metal filament, a mix of plastic & metal powder, which might be ideal
These have got very sophisticated now. Papadakis Racing had an exhaust manifold 3D printed in Inconel. That's about as a tough an environment as you'll find for any partthere are printers which work by shaking down a thin layer of metal dust,
The thin aluminum that Neumann uses helps the mic body not be especially resonant.So for you, the best alloy would be brass ?
Or aluminum ?
Some manufacturers use brass, which is pretty resonant
I’m sure that some manufacturers have done things along those lines. I’m not sure if it was always for resonant quality.Has anyone ever tried using something like PlastiDip rubberized paint to damp resonance in a metal shell?
CAD coated some of their condensers in a rubberized coating. It didn’t necessarily age well. I think there are some others that did the rubber coat.
