Here's how Dan Alexander does it:
Hard to go against instruction from Neumann, but sometimes i wonder if they are aware of all the quirks. In the end, if things go south, they can replace the whole thing.I had discussed this with Neumann and they provided me with a description on how to clean them. Of course that email is long gone, but basically, carefully drip feed distilled water across the membrane surface, its good to have say a white saucer/dinner plate underneath collecting the water so you can see if any particles come off, hopefully no gold plating. If there appears to be foreign particles still on the surface that are not washing off, use something like a lens brush, the finest hair brush you can source and gently brush while running the distilled water across it. If you see any gold particles, stop brushing immediately. Cleaning with a brush should only be done if there is a performance issue with the microphone and not something you should do periodically. If you have a condensor that shuts down for a number of seconds, could be 10 -15 seconds at high sound pressure levels, then it most likely needs cleaning. After cleaning, with an open mouth, softly "huff' on the microphone surface, it should no longer shut down.
I will clarify, the instruction I received from Neumann was specific to a vintage U67, it may not apply to other mics and capsules. It is always worth contacting the manufacturer, they should know best. And the surgery was very successful, I had a problem with the mic muting of sorts for more than 5 seconds with slow recovery over a longer period on high sound pressure levels (vocals)Hard to go against instruction from Neumann, but sometimes i wonder if they are aware of all the quirks. In the end, if things go south, they can replace the whole thing.
Here's the original capsule with cut in the spacer. One should at least be aware of it if liquid is used.
i wonder if one could use an engineering fluid like a novec
This is how I do it to. No damaged capsules yet. I once tried my best to remove the gold from a capsule from the 50's with a squirrel hair brush but I cound't get it off.Distilled water and a squirrel hair brush
I've cleaned hundreds of capsules
It seems it is usually the dust getting moisture that makes it short out though, so whether or not cleaning needs to remove more than dust is probably debatable.Most of the gunk I've seen on vintage Neumanns wouldn't be touched by water.
Skin oils and tobacco tar are not water soluble.
Ammonia and pet are not chemically compatible according to the data sheetsI remember reading at various times - in different sources - that AKG, Neumann, and others have tested their products against ammonia. Probably a better idea than alcohol.
Testing and cleaning are different things. I wouldn't put ammonia anywhere near a capsule no idea what it would do to mylar but it corrode's brass and other metals.I remember reading at various times - in different sources - that AKG, Neumann, and others have tested their products against ammonia. Probably a better idea than alcohol.
I just know a mic I don't mind risking is noisy and I've cleaned the PCB already. I wouldn't clean something like my C414 B-ULS cause that works fine.Ammonia should only be used to clean acrylic. Ammonia will oxidize brass but I would be surprised if it would actually dissolve it. I have had brass in ammonia baths and sealed chambers with ammonia gas and all that achieved was darkening it's color. Ammonia however is very good at dissolving gold.
For cleaning membranes I would only recommend distilled water or distilled water with a little alcohol added .
Neumann/Gefell M7 capsules have a tiny hole at their perimeter.
Dry cleaning fluid has been mentioned at various times but then I would say that you are more concerned with looks than performance. A slightly dirty capsule will usually perform excellently.
